API for translating Onshape document model into its exported format
in General
I am new to Onshape.
I have seen that there are some rest API available for OAuth.
I want to test and try each and every steps from fetching access token to access document and translating the model into Onshape available format (eg., 2D drawing to dxf).
Any help or suggestion would be helpful. Currently I wish to try these operation through API endpoints in Postman.
Thanks
Thanks
https://onshape-public.github.io/docs/
When you have a document with this loaded, you can just fill in the keys and parameters on any api and get the JSON response. Not quite Postman, but convenient. I suppose the next step is to do the same with Postman. Figure out the OAuth to get Postman connected, and then replicate these calls that you can do in the API explorer.
www.virtualmold.com
