iPad. MOVE. Sketch or Body
chris_heath456chris_heath456 Member Posts: 2
Hi. Just started using Onshape on my iPad Pro but I can’t find any Help about moving sketches or bodies.  I tried selecting the body and then dragging my pen but noting moves. There are no constraints as far as I can see. Really sorry that this is such a simple thing to do. Thanks for your help.
    Assemblies are created in the assembly tab at the bottom. You can't move sketches because they are used for modeling.
  • angelo_scozzarellaangelo_scozzarella Member Posts: 58 EDU
    In my Onshape for ipad pro i Can moving sketches and also single object with command Sposta/Copia
    And you can also moving Parts and Surfaces.
