CloudMilling - Full-Cloud CAM Solution
michael_22
Member Posts: 6 ✭✭
CloudMilling was created to democratize and modernize CAM. For too long, the market has been dominated by systems that are either out of reach, via monetary or other means, or are inadequate for the job.
We believe that anyone, and everyone, from hobbyists and students to professional engineers working at multi-billion dollar conglomerates should have access to the same CAM system.
In the same way, CloudMilling was also built to utilize the most used platform in the world: Mobile devices. Imagine using CAM at the machine to tweak the parameters in case you want to cut a job on a different machine, or with different stock. The possibilities are endless.
- Cloud-Based Solution - Use CloudMilling anywhere on any platform that has a browser, even on your mobile device. No need for expensive workstations.
- Multi-Axis Machining - From 2-Axis to 5-Axis, CloudMilling can machine any job with its cutting-edge tool paths.
- No Compromises - From hobbyists to professionals, CloudMilling can be used by anyone, without compromising expert features.
- Zero Maintenance - With no hardware or licensing requirements, CloudMilling eliminates the use of license files, or dongles, and reduces the need for IT support.
- Onshape Integration - Machine your Onshape parts easily with CloudMilling's full integration.
RENDERCAD
rendercad.ai - Photorealistic product rendering.
Hope this answers your question.
Thanks,
Mike
We can create a post processor for your machine on request.
The price is for a single version of a part. So, you can add, edit, and post tool paths, etc., but, if you change the part, you will be charged again. In the case of 3 revisions, you will be charged $30.
We are looking for feedback on this.
Hope this answers your questions.
Thanks,
Mike
That is correct.
We are planning to release a getting started video this week.
The basic concept of CloudMilling is Job -> Machine -> Setup -> Tool -> Tool Path, the same order as the buttons in the top left light up. I see that you managed to get to the Setup step. Next, you'll want to create a Tool operation, then you can finally create a Tool Path operation.
In order to import a Onshape Part Studio, you change the Component Source to Onshape when you add a Component. This will show Document, Workspace, and Part Studio, which you must select in that order.
Hope this helps.
Thanks,
Mike
Thanks,
Mike
First impressions:
Note: I really want this to work, I think the idea is fantastic and could take over a lot of the CAM industry if it goes well.- There were no email notifications from the beta application, I found the app in the app store at random.
- I could not import a part from the current studio the app was located in.
(Suggestion: Parts should be picked similarly to the import tool in the Onshape drawings.)
- The app was viewing all of my documents, not just the one I placed it in. This is a security breach for me.
(Suggestion: Only current studios from the current document should be shown.)
- The menu user interface was not intuitive. It is drop down menu after drop down menu. I could barely function with it.
(Suggestion: Create a more visual menu user interface like Onshape studios or assemblies.)
- The machine axis options and tool path options were impressive. I was unable to test them due to the current menu interface and the amount of time I was willing to spend.
- Surprisingly, the app supports a 3D Connexion Space Mouse! Unfortunately, the movement was too laggy and slow to use efficiently. The standard right click mouse drag was fine.
Summary
- The menu user interface is not currently usable for the amount of time I am willing to spend.- Models from the current document need to be the import priority.
RENDERCAD
A series of progressive videos would really help. For me this would look something like this:
Simple 2.5d part with some holes
- Part/Machine setup. The program does not allow assemblies so work arounds would be nice.
- Tools/Holders/Speeds/Feeds
- Roughing
- Facing
- Profile
- Drill/Tap
- Post Process
More complex 2.5d part- Pockets/Closed Pockets
- Cbore/Chamfer
- Radii (form tool) and chambers
Simple 3d part- Surface Radii
- Ramps/Convex/Concave
4-axis part5-axis part
I am in love with the idea of cloudmilling! I think you have an advantage over traditional cam systems in that you can easily monitor the clicks. This allows you to streamline processes. Less clicks is always better!
RENDERCAD
