Toggle selection behavior from multiple to regular Single select
gda_ctogda_cto Member Posts: 13 PRO
edited August 2021 in Product Feedback
I would like the ability to change the selection of items behavior. I personally find the multiple selection behaviour unintuitive, frustrating and wastes a lot of time.
In almost every other computer program, the default selection of items behaviour is to select individual items until you hold the ctrl or shift key (with some minor differences in certain views).
I get that OnShape has it's own way of doing things, but I feel that those things that are different from the default behavior of most programs or even the operating system, those should be something you can change to standard behaviour, just as you made the different mouse controls user selectable.
    This is a behavior we have built into everything in Onshape and is part of our foundational ux.  At this point we are not considering a change at this time.
  • S1monS1mon Member Posts: 4,081 PRO
    I also have to say the behavior is odd, and painful to get used to. I tell myself it's to make the UX between mobile and desktop more consistent, but I'm really not sure what was going through Onshape's UX team early on.
    What I can say is there are a couple things which make it tolerable:
    1. The cursor has a little number next to it when you've made selections (1, 2, 3 ... up to "5+"). This is the count of selected items.
    2. Use the spacebar shortcut to deselect on desktop.
    edited March 2022
    S1mon said:
    The cursor has a little number next to it when you've made selections (1, 2, 3 ... up to "5+") [...]
    This would be nicer if it went up to as many items as you had, rather than just 5...
    IR for AS/NZS 1100
  • eugene_kozlenkoeugene_kozlenko Member Posts: 2
    I couldn't agree with Andreas enough. For somebody that doesn't use Onshape exclusively, the always on multiselect on the desktop is by far the most disruptive thing to my flow, and is my biggest pain point with the software. I will pay money for access to a setting somewhere that lets me multi select with CTRL instead.
    I understand how it could be hard to empathize on something like this if Onshape is the only CAD you drive, but to me, the multi select default is the equivalent of somebody sneaking into your house every weekend and swapping the hot and cold pipes on all of your faucets. By Saturday afternoon, you'll only get scalded a third of the time, but life would just be a lot better if this wasn't the case.
  • scott_lakescott_lake Member Posts: 8 ✭✭
    edited March 2025
    This behavior does not seem to have been in the UX from the beginning, and it's certainly not the UX of heritage; that being SolidWorks. Please provide a means to toggle between what your claim is of it being foundational, and a selection mode that everyone coming to your product expects - that is to requiring some sort of hold down of a key to multi-select.
    Even when launching a new document - to simply select one of the three planes at the origin, the selection is defaulted to multi-select. There are no other objects in the document - just the default planes. To force the user to escape from multi-select, when there are no actual objects present - this makes absolutely no sense as minimally at least one sketch element needs to be present to select. I have been a long time occasional OnShape user, and this behavior right at the onset of a new document seems to be a recent change, and not one that is foundational to the UX.
  • Jerome5Jerome5 Member Posts: 5 PRO
    Hi,
    I'll add my agreement to both Ed_In_3D & Andreas.
    • I've previously contacted support about the dysfunctional nature of the 'persistent' methodology & got a rather dismissive response
    • Also, I find it's not something to 'get used to'…the very persistent nature is truly is a roadblock to efficient & productive workflow
    As another point to this:
    • I've used NX for 6 yrs which also has a similar functionality but they've done a much better job of it
    • They have both judiciously applied it when it makes sense & then far more strategically & user friendly, they acknowledged that it may not suit everyone's workflow & have on/off toggles in their settings (in fact, they have a very deep settings menu to allow customization of just about everything)
    If I may offer some take away's for Onshape:
    1) There's a big difference between 'disruptive' & 'dysfunctional' workflow creation
    2) Corporate users are a completely different market than casual 'makers'…our corporate design time translates into dollars/cents, hitting timelines or not & frustration/ease of use
    3) Tying these together….you have to have a default offering of course but give users the ability to set up Onshape on their terms for maximum benefit
    Thanks.
