API Part Numbers
Hugh_GoodbodyHugh_Goodbody Member Posts: 41 PRO
Does anyone know if it is possible to get and update the part number in the release management settings with the API?
For example, run a script to populate part numbers - starting with the last number in the part number settings then incrementing by 1, then after all parts are numbered set the part number setting to the next useable number.
I know auto numbering can be carried out in a BOM table, but sometimes BOM's or assemblies are unnecessary.
  • NeilCookeNeilCooke Moderator, Onshape Employees Posts: 5,983 image
    No - but you can set part numbers in the part properties dialog.
