Beam deflection
Steve_willitsSteve_willits Member Posts: 2 PRO
Hi,
Does Onshape have beam deflection analysis?  I am looking for something simple like calculating the maximum deflection of a steel bar, supported at both ends, with load in the middle.
Thanks,
Steve
  • GregBrownGregBrown Member, Onshape Employees, csevp, pcbaevp Posts: 316
    edited July 2021 Answer ✓
    There's nothing built in, and using a full featured simulation code (FEA) would be way overkill if (as you describe) you are only looking for simply supported/mid point loaded bars. The formula for calculating the max deflection (max d = FL^3/48EI) is simple enough, along with I (I = bh^3/12 for a rectangular solid section; other sections easily found online) - so it would be easy to set up a couple of variables as inputs (F, L, E, I, b, h) and spit out a result.
    Alternatively you could built a CustomFeature that takes a selected edge, various inputs and displays a max deflection. It would be a great learning exercise as this would be a very simple one. I had a quick bash at it:
    Edited to add my public doc:
    https://cad.onshape.com/documents/0bb2acf917e0c2f890197ca7/w/34d26b4ab5b6c3e4ceeb688c/e/f94fb66fd110abfbfb51de27
    I also included a part studio that does it simply with variables. Use the variable table  for the best way to view :)
  • TimRiceTimRice Member, Moderator, Onshape Employees Posts: 315
    I do have this super old custom feature that used the beam equations to calculate beam deflections:
    https://cad.onshape.com/documents/21fa541ca92d7d95aea12b6d/v/8b31dd78d7faf7097352ce7b/e/a7050d236d39980ebd6a0bc3
    Onshape, Inc.
