Milky Coloured Surface
ian_pedleyian_pedley Member Posts: 8
Hi Guys,
New to the forum.
My last two designs have developed a milky appearance on the top surface towards the end of the procedure.
Any ideas what this could be?
  • NeilCookeNeilCooke Moderator, Onshape Employees Posts: 5,952 image
    Sorry @ian_pedley but this made me laugh. Can you show a pic or share a URL?
    edited July 2021
    @ian_pedley
    OK this is kind of interesting
    Now if you’re talking about a part that you have manufactured using a 3-D printer, then I wouldn’t know what to say
    But, if you’re talking about the look of your part within the Onshape app as being milky looking, then it’s possible you have a plane turned on and you’re looking through that plane at the part, which gives it a kind of milky appearance
    Could it be overlapping/coincident surfaces?
  • ian_pedleyian_pedley Member Posts: 8
    Thanks for your suggestions guys.
    I have done many designs but strangely, my last two have retained a 'milky' top surface (see attached pic).
    It's probably something I'm doing but is there a fix?
    edited August 2021
    I forgot to add that all the planes are turned off in the above view so cannot be causing the 'milky' appearance.
  • John_P_DesiletsJohn_P_Desilets Onshape Employees, csevp Posts: 270 image
    @ian_pedley Thats just a sketch on the face. If you hide the sketch that will go away.
  • wayne_sauderwayne_sauder Member, csevp Posts: 634 PRO
    Shift P is a great shortcut to keep in mind for things like this.
    Thanks guys. A great help. It was indeed a sketch that need turning off. Peachy now.
