how to assign a variable to control number of sides of a polygon?
dhiraj_patil
dhiraj_patil Member Posts: 3 ✭
I want to assign a variable to control number of sides of a polygon. But it won't accept the input.
  • Alex_Kempen
    Alex_Kempen Member Posts: 258 EDU
    Sketch patterns and polygons cannot unfortunately be controlled with variables. This is due to the way Onshape handles creating new sketch entities internally; new entities aren’t processed deterministically, so increasing the number of sides on a polygon and then changing it back will cause things which reference the sides of the polygon to behave unexpectedly and inconsistently.
     One alternative to configuring polygons directly is to make multiple polygon sketches and to use configurations to switch between them.
    Also, note that variables are called in Onshape using a # - this also activates the variable autocomplete menu.
  • Alex_Kempen
