[FIX] FS Beam
emagdalenaC2i
Hi @NeilCooke
There is a small bug in the Beam FeatureScript
To fix it, just replace in the "Beam Feature" tab the line 105:
if (!definition.setCustomName)
to
else
This is the code I use:
<div>if (definition.profileType == ProfileType.CUSTOM)</div><div>{</div><div>	annotation { "Name" : "Override", "UIHint" : "REMEMBER_PREVIOUS_VALUE" }</div><div>	definition.setCustomName is boolean;</div><div>	if (definition.setCustomName)</div><div>	{</div><div>		annotation { "Name" : "Name", "Default" : "Custom Profile", "UIHint" : "REMEMBER_PREVIOUS_VALUE" }</div><div>		definition.customName is string;</div><div>	}</div><div>}</div><div>else</div><div>{</div><div>	annotation { "Name" : "Standard", "Default" : false, "UIHint" : "REMEMBER_PREVIOUS_VALUE" }</div><div>	definition.nameStandard is boolean;</div><div><br></div><div>	annotation { "Name" : "Profile", "Default" : true, "UIHint" : "REMEMBER_PREVIOUS_VALUE" }</div><div>	definition.nameProfile is boolean;</div><div>}</div>
Un saludo,
    NeilCooke Moderator, Onshape Employees Posts: 6,113 image
    Thanks Eduardo - the standard/profile option is still required for custom profiles. If they have been tagged then this data will be used, if not, the user can override and enter a different name.
    I used:
    if (definition.profileType == ProfileType.STANDARD || (definition.profileType == ProfileType.CUSTOM && !definition.setCustomName))
    Feature versioned - thanks for finding this.
  • emagdalenaC2i
    You probably like this vídeo ;-)
    https://www.youtube.com/watch?v=tn3-0H63RfQ
    Un saludo,
    VERY NICE!!
