LOCATING WHERE THE PDF GOES
Richard_StrahmRichard_Strahm Member Posts: 1 PRO
Is there any way when i create a PDF file that it will know where i want it to go.
And if the pdf file is moved, it will print the location in small letters on the bottom
example:
  • NeilCookeNeilCooke Moderator, Onshape Employees Posts: 5,952 image
    Hi @Richard_Strahm - when you export a PDF, it is the browser that decides where it goes. You can set a location in the browser settings, but that affects every download from every site. Also, Onshape has no connection to your local filesystem so there is no way that we can know anything about your device. You could possibly do this with the API, but that is a lot of work if you don't know what you're doing.
