measure in specified coordinate(mateconnector)指定座標での測定
Toshimichi_OdaToshimichi_Oda OS Professional Posts: 62 PRO
指定した座標系で測定できますか?
アセンブリを作り 部品を配置することが必要ですか?
Can we measure in the specified coordinate system (mateconnector) ?
Is it nessesary to creat an assembly and put the part ?
  • NeilCookeNeilCooke Moderator, Onshape Employees Posts: 5,988 image
    The Sensor custom feature lets you select a mate connector to define the coordinate system (find it in FeatureScript samples).
  • Toshimichi_OdaToshimichi_Oda OS Professional Posts: 62 PRO
    Thank you.
    Sensor FS is :
      one of 'X','Y','Z' is measured in specified mate connector, and displayed result compared.
    Measure dialog is :
      all of minimum distance, 'X', 'Y' and 'Z' are displayed with length units specified
    user's preferences.
    I request that measure dialog has a selection of mate connector.
    I request additionally that
      in sketch mode default of mateconnector of measure dialog is coordinate of the sketch.
