Adding/Deleting Spline Points is not Mirrored
S1mon
Member Posts: 3,883 PRO
Unlike other CAD tools, if you have a mirrored spline, adding or deleting a spline point doesn't update the mirrored spline - it just generates constraint/solver errors. To me this is a bug, but if necessary, I can create an improvement request.
[edit] On further investigation, constraints that worked fine in Solidworks are not solving as easily in Onshape. A very simple spline with a few constraints will allow adding/deleting of spline points, but the minute the constraints are slightly more complex, it gives up. Also in retrospect, mirroring splines and adding/removing control points got much more robust with style splines - not b-splines with through points.
