Affordable milling software
dirk_van_der_vaartdirk_van_der_vaart Member Posts: 561 ✭✭✭
Affordable milling software, 15 $ per month subscription, named Carveco.
https://carveco.com/carveco-software-range/carveco-maker/
This a spin-off of Artcam a part of Autodesk
I have worked with this for many years, very good, postprocessors for almost every machine.
Easy to learn.
For as long as Onshape has no milling tools build-in
    @dirk_van_der_vaart
    thanks so much for sharing this.  Both Powermill (high end CAM) and Artcam were Dellcam products before purchase by Autodesk.  We use Powermill for model, tool, and pattern making Accurate Pattern. Over the years, I had been somewhat interested in Artcam for special projects and was sad it went away.  Now I am going into my next life stage and Carveco will be a great tool for my upcoming 'retirement career/hobby'
    www.accuratepattern.com
  • MichaelPascoeMichaelPascoe Member Posts: 2,775 PRO
    Thanks!
