Setting up an Assembly flat / square to a plane for a drawing
patrick_sheapatrick_shea Member Posts: 63 ✭✭
In the learning phase here - I am creating a simple model, and the assembly is not lining up on a plane for the drawings to be generated 'Nicely'.. It is 2 simple pieces, but when assembled, it is a bunch of compound angles, that don't want to mate nice for a decent drawing.  Help !!
Patrick
  • Jake_DelanoJake_Delano Member, Onshape Employees Posts: 43 image
    Hi Patrick, assembling in Onshape will be done a little bit differently than you're used to in other systems. I'd implore you to check out our Intro to Assembly Design Learning Center course to show you how to properly mate things inside Onshape. If you'd like the two objects to be on the same "plane", because Onshape assemblies do not use planes, I'd suggest using either a fastened or parallel mate with limits and offsets set to have them be aligned as you intended.
  • john_mcclaryjohn_mcclary Member, Developers Posts: 3,998 PRO
    If you link your document, we could take a look and help you come up with a mating strategy for this part.
