Connect Linear Pattern Around a Curve
![sam_biddle](https://cad.onshape.com/images/placeholder-user.png)
Is there an easy way to get this pattern to rotate around this curve? I have a linear pattern on the flat faces, but am having trouble getting it to bend well around the curve using arcs. Is there an easier way to do this? Thank you.
![Image: https://us.v-cdn.net/5022071/uploads/editor/ae/zan2uoq7am48.png](https://us.v-cdn.net/5022071/uploads/editor/ae/zan2uoq7am48.png)
Please share your document for the best help - see instructions here.
In answer to your original question - I suggest extruding the corners using curves like you have in blue. I just made a closed region and extruded the first. Once you have the 2nd level shape, you can do a simple linear pattern.
Other suggestions: constrain your sketches and use symmetry (mirror and pattern to the tangency of corner for example). Both will make your models more robust and easier to design/modify.
Here is the way I did the first layer - https://cad.onshape.com/documents/2ce02718c1e5413edc678e23/w/9e60f46e84b4e743b43f0db4/e/aee48ba5b59607b0ee592134
