Export DWG
nicola_malagnininicola_malagnini Member Posts: 35 EDU
hi.
how i can export an object in .DWG file?
thanks
  • john_mcclaryjohn_mcclary Member, Developers Posts: 4,043 PRO
    if it is a part, then right click and choose export as DXF/DWG
    if it is a drawing right click the tab and select export
    then choose DWG from the format drop down
    if you want the flat pattern of a part then open the sheet-metal view and right click the part, then export
  • nicola_malagnininicola_malagnini Member Posts: 35 EDU
    edited October 2021
    mmmmm. i tryed this but the part was exported only in 2d and not in 3d. if i select all the part, when i try to do 'right click'
    i don't have 'Export Dwg' but only 'Export'
    Right, dwg and dxf can contain 3d objects. But that format is typically expected to be 2D when exporting.
    Instead, use the export option, then choose step from the list. Or whatever format your other application can import
