Isometric section view?
Cedric_Eveleigh
Member, OS Professional, csevp Posts: 72 PRO
in Drawings
Is it possible to create an isometric section view in Onshape drawings? For example, the part in an isometric section view could be sectioned in a plane that is parallel to the front plane.
1
https://cad.onshape.com/documents/bdffe7bf48f3b4155e85d073
In combination with, say, Neil Cooke's wire mesh feature:
https://cad.onshape.com/documents/812383b6012526bce6bdfff9
Then, combine the grids/wire meshes into a closed composite part to keep things tidy, and put their suppression under a configuration:
In the drawing, insert the whole part studio with the sectioned configuration for your iso view and just the unsectioned part by itself for the other views:
While this isn't exactly standards-based, it's probably good enough for communicating the design.
Document link: https://cad.onshape.com/documents/ae71a9f8b878c16427925fdd
Note: if you have a part studio with multiple parts, you could make another composite part (probably best to do it open to keep appearances in case you need a shaded view) that contains the mesh composite part + your part to use in drawings. Then, insert the composite part instead of the whole part studio for the iso view.
Any ability to do this now?
have you tried named views?
