Extrude removing hole for set screw
Trying to create a pulley wheel with a set screw hole. Found a threaded hole in the public repository and am now trying to extrude the wheel and connect it with the threaded hole. When I extrude the wheel it intersects and fills in the threaded hole. How do I intersect the two and keep the threaded hole?
https://cad.onshape.com/documents/659fb1fc93be3c9bfb60f371/w/89491833fb27f86ba09ed205/e/15a163a0123d40804f4f6cbc?renderMode=0&uiState=61808c8e22e8c0568fe7e5a6
Thank you
Thank you
https://cad.onshape.com/documents/644fd652bc14a0d19d4ce0bd/w/d54a2950756d3d6aada90ade/e/694bff139a4ed56d002d649a?renderMode=0&uiState=6180f5537ae9f613a2c180b8
