Is there a way to make the sketch plane unselectable while sketchig?
For reference. When sketching the grey area is a selectable area, as I am trying to select lines I end up grabbing the area instead and it's very annoying when trying to select chains of things. I have literally yet to have use of needing this area being selectable in the 7 months I've been using this software while sketching.
Thanks
  • _anton_anton Member, Onshape Employees Posts: 503 image
    If the aim is to select loops of edges, right click -> Create selection... can be easier than doing it manually.
  • Jacob_BoyerJacob_Boyer Member Posts: 4 PRO
    That will help me a lot, thank you!
