Golberg polyhedron
carter_r
carter_r Member Posts: 4 EDU
Does anyone know how to create golberg polyhedron?
    S1mon Member Posts: 4,612 PRO
    edited November 2021 Answer ✓
    It looks like there are a lot of flavors of Goldberg Polyhedrons, so you're going to need to be more specific.
    Is your goal to create a parametric model or just to have a model?
    If you haven't seen this already, there's a great site which allows you to explore polyhedra, it might give you some ideas.
    Linked off of there, I found this which could be useful if you want to download the coordinates and then come up with some featurescript to create the shape in Onshape.
    @carter_r
    Sorry, I'm just good at Google and collecting interesting CAD/geometry links.
    There's a public FeatureScript that makes a lot of different polyhedra, but I'm not sure how easy it would be to get what you want out of it. There's another FeatureScript which handles Convex Polyhedrons, but the comments are all in Russian. It apparently takes an unordered set of points, and creates a polyhedron from that. Maybe between these two, you'll get some ideas...
    There's a thread about the two FeatureScripts.
    If I had to do this myself, I'd start with the most simple polyhedron you want, and try to write some FeatureScript that would take the coordinates info from the dmccooey.com site, and build surfaces. One clue is that offset surface of 0, with a sketch as an input will create a flat surface.
    These polyhedra all have some symmetries and patterns, so you really only need to build parts of the polyheadra and then figure out how to pattern it.
  • carter_r
    Thank you for helping,
    in a site linked to the polyhedron visualization site you gave me I found dual geodesic icosahedra http://dmccooey.com/polyhedra/DualGeodesicIcosahedra.html
    these are the shape that I would like to create. Do you have suggestions on how to take the information in this site to create the e polyhedron in onshape?
    again thanks for responding, I’ve
    @carter_r
