Is there a way to change values of variables depending on an Enum selection?
I am relatively new to custom FeatureScripts and I am trying to create a list of variables. I would like the value of those variables to change depending on what choice I have made in the dropdown menu.
I want the choices inside the blue bracket to change the value of those inside of the grey bracket.
  • EvanReese
    EvanReese Member, Mentor Posts: 3,096 PRO
    edited November 2021 Answer ✓
    Actually, thinking more about it you could make each variable it's own map and just use the enum value as the key. It has to be made into a string to work, but I think I like this way a lot more. Here's an example.
  • EvanReese
    There's probably a more elegant way, but you could do it with if statements.
    if (definition.myEnum == materialType.SHEET)
    v.GA30 = 0.0120*inch;
    // and so on...
    else if (definition.myEnum == materialType.STAINLESS)
    v.GA30 = 0.0100*inch;
    // and so on...
  • EvanReese
  • david_dalton526
    david_dalton526 Member Posts: 3 ✭
    Thank you so much. I previously thought of using a Boolean expression but I knew there had to be a better way. I haven't messed with strings too much but, I can see that it is a very helpful tool to have.
