Circle diameter snapping or automatic equal diameters when making multiple circles
Jordan_EnglundJordan_Englund Member Posts: 19 ✭✭✭
edited November 2021 in Using Onshape
The sketch fillet tool allows you repeatedly make sketch fillets where each fillet defaults to the first fillet's radius (and is automatically constrained with equal radius).
Is there the ability to do this when making several circles in a sketch?
How about a way to have successive circles snap to the diameter of the first circle (and automatically become equal diameters) if you drag them to approximately the same diameter?
  • PeteYodisPeteYodis Moderator, Onshape Employees Posts: 577 image
    @Jordan_Englund I have created a ticket for this, as it's an improvement we have for sketch circles.
  • Jordan_EnglundJordan_Englund Member Posts: 19 ✭✭✭
    @PeteYodis Does that mean that it is a feature that exists but isn't working for me? Or does that mean that the feature doesn't exist yet but you plan to add it later?
    @Jordan_Englund It means the feature does not exist yet, but I have added you to the improvement for it via our ticketing system.
  • Simon_KozinSimon_Kozin Member, csevp Posts: 9 ✭✭
    Yes, it would be amazing to automatically sketch equal circles without having to go back and select a bunch of sketched circles and apply the equal constraint after the fact. I find myself doing this all the time!
  • tom_kazakovtom_kazakov Member Posts: 2
    I very often find myself wishing there were a way to pre-apply equal constraint to several circles I'm sketching in a row.
  • Darren_A_HenryDarren_A_Henry Onshape Employees Posts: 69 image
    edited January 12
    Neat idea….A quick tip on this subject is to select the circles using a window select, then add one equal constraint. Many people are unaware that you can apply the equal constraint to multiple selected entities. It might be difficult if the sketch is complex.
