Is there a quick indication of parts with high tessellation quality?
james_howard360
Member Posts: 28 PRO
I was troubleshooting a relatively simple assembly with a 600ms regen time but that took 20 full seconds to reload. Finally realized that one of the parts was set to "very fine" quality; I must have used the setting and forgotten. Is there an easy indicator that shows tessellation quality without checking the appearance of parts individually?
Hi,
You can use the performance panel to view all the parts with very fine tessellation and other performance related information. I've attached a screen shot of what it looks like. More information on the performance panel can be found here : https://cad.onshape.com/help/Content/performance_panel.htm
1
Hi,
1 -
Ahh thank you, I had been using the regen timer window from the feature tree and missed the performance panel.0
