Simple gear relation question
Question:
I am rying to create the gear relationship between the two gears, which are "revolute mated" to the yellow housing. They revolute fine by themselves, but the gear relation between them would not animate. The error message is "Some steps were computed, but there was an error: Unable to apply transform. Instance(s) may be constrained. "....
I am not sure if it is because the... I am not sure at all. I am new to the software.
Thank you
  • NeilCookeNeilCooke Moderator, Onshape Employees Posts: 5,957 image
    Not sure - try right-clicking the yellow frame and select "Fix"
