Is there a way to Lock the Z-axis of the part, when using the mouse to rotate the view of the part?
in General
Hello
When using your mouse to rotate the part, is there any way to "genuinely" lock the part so that the view can ONLY rotate around the Z-axis of the part itself?
Holding down Alt + RMB is doing something different... (It does keep Z-direction lines vertical, however also allows you to "pull the Z-axis of the part towards you" as is were...)
J
J
Improvements to Onshape - August 11th, 2023 — Onshape
Hi, is there a way to do this on the iPad?
Also curious to learn whether there's a way to do this.
