add line break in dimension
Murray_2
Murray_2 Posts: 12 PRO
edited January 2022 in Community Support
Is there a way to insert a dimension line break to keep drawings tidy?
The red line in the attached image is where I would like a break.
Thanks in advance.
    NeilCooke Posts: 6,097 image
    I try to not make them overlap by removing the leader between the arrows and moving the 1.5 dim further down. You are absolutely right it should be able to do it - please create an improvement request in the category on the right —->
  • john_mcclary
    john_mcclary Posts: 4,095 PRO
    No, sorry
    I never knew that was a thing
  • Murray_2
    oh :-), It was feature in Creo that I used all the time.
  • Murray_2
    Thanks Neil, I'll give that a go, and make the request .
    Hi Neil, how do you remove the leader between the arrows?
    @Reilly_Palmer you can only do it with an ANSI template, so if you want ISO you can start with an ANSI template and modify it to meet your ISO requirements (there is an option in the drawing properties panel to set text aligned with dimension - however, the text is still inline rather than above the dimension line which is not ideal). An improvement request to make this an option would go a long way ----->>>>
