Using Mate Connectors
paul_sundstrom
edited January 2022 in Community Support
I am/was a reasonably proficient user of Solidworks but no longer have access to a licence.
I have been playing around with Onshape, and expect to be buying a licence shortly.
Image 1 shows part of a bracket arrangement with a cylindrical shell segment attached to a flat bar.
I am having trouble mating the shell piece properly with the flat bar. I need to rotate it about the z-axis so it is symmetrical with the flat bar. To make this mate I am trying to set up suitable mate connectors on the shell and flat bar. In sketch editing mode I have positioned a mate connector which can be seen in Image 2, but I cannot see it on the part when in assembly mode.
How do I get access to select that mate connector when in assembly mode?
Is there a better way to set the mate to align the parts properly?
Thanks in anticipation. Cheers, Paul
  • steve_shubin
    steve_shubin ✭✭✭✭
    edited January 2022
    Is there a better way to … align the parts?
    One option is – make both parts in the same part studio — in the position that you want them relative to one another
    Then insert them into the assembly, and group them
  • To show/hide mate connectors, hit K. Mates can be realigned/offset by either using the offset checkbox in the mate dialogue or by realigning or moving explicit mate connectors on the parts themselves.
  • Hans_Ole_Leirvik
    edited June 2022
    You must draw both parts in the same Part Studio in the required positions in relation to each other.
    Then place a Mate Connector(MC) on an automatic proposed MC and let the other part own it.
    Then it it very easy to mate them together in an assembly.
    I draw all parts in the same one part studio in the locations they shoud be in, in the finished product.
    Only when the regeneration time of the Part Studio reaches 7 seconds I continue with more parts in a new part studio.
    In the new part studio I use Derive to copy over the parts/sketches I need to continue to design new parts in realtion to the parts in the other part studio.
    Multi part studios is one of the great features of Onshape :)
  • @paul_sundstrom if you make your document PUBLIC and post the url here I bet you'll receive multiple solutions from the community.
