document tab color selection
Joshua_FreedJoshua_Freed Member Posts: 2
I would like to be able to set the color of each of the document tabs at the bottom of the workspace so that I can set colors to represent whatever I want.
  • NeilCookeNeilCooke Moderator, Onshape Employees Posts: 5,951 image
    Hi @Joshua_Freed - as a professional plan user, you should submit improvement requests via the "Contact support" option in the help menu. A request posted here is likely to get lost/ignored. Thanks.
