No preview, no drawing print
in Drawings
I created an assembly drawing sheet and then used the top left of the screen Chrome "hamburger" menu to access the print menu.
I clicked print, got the Windows print facility screen and a message that said "downloading preview".
After the message went away, there was no preview. Just a blank page. I printed the preview anyway and it printed a blank page.
I disabled uBlock in Chrome and tried to print again, with the same result.
Help.
Help.
Can you take screen-shot and send it to Onshape support team.
I opened the model to the "Assembly 1 Drawing 1" tab.
I clicked on the Chrome "hamburger" icon at the top left of the screen.
The print dialog window opened and displayed the message " creating preview", followed by a blank print document.
The java console displayed the following errors:
"Failed to load resource: the server responded with a status of 401 (Unauthorized)
Failed to load resource: net::ERR_CONNECTION_REFUSED
Does this help anyone figure out why I can't print my On-Shape drawing?
FYI. I don't know if this is significant, but "3dconnexion" is my 3D pointing device.
The other way to print a drawing is to right-mouse-button click on the drawing tab at the bottom of the window, and choose "Export to PDF", then print the PDF file.
Do you mean top right?
@thomas_holford, currently drawings tabs use the Print command in the Onshape "hamburger" menu to create a PDF and automatically open it in a new browser tab.
Users have reported several problems with this process and our plan is to adjust it to match the standard browser print workflow which you seem to be expecting.
So it's 9 years later but I was having this same problem (blank page, nothing to preview) when trying to just print directly from an assembly view, not a drawing. I changed my browser to not be full screen on a 4K monitor and then it worked. After playing with it a bit more I finally realized that when you click the Onshape hamburger followed by print you get a printer setup dialog (paper size and portrait/landscape). At this point pay attention to the dashed rectangle on the screen as this is what will print. I'd tried to move my rendering to the top left of the browser window to avoid large margins but I needed to move it to the top left of that rectangle.
