Arcs in drawings
Tyler_NeufeldTyler_Neufeld Member, csevp Posts: 5
I'm trying to draw an arc that shows two circular features are coradial with one another. However the only tool that seems obvious to do it is drawing a full circle, using three-point circle or two-point circle. And doing that would take up too much room on the page. I'd be fine with drawing a circle if there was a trim tool, but that doesn't seem to exist in drawing mode.
  • romeograhamromeograham Member, csevp Posts: 733 PRO
    You would need to create the sketched arc in your part studio - then show that sketch in the drawing. Right-click on the Drawing View > Show Sketches. Then you select the sketch you want to show.
