Rotating a part in an assembly around a shaft not aligned to the coordinate system
ricardo_raimondo
Member Posts: 68 ✭✭
in Drawings
I am assembling an airplane wing with its aileron. I have the wing fixed. Both parts have a shaft, that acts as the hinge between the parts. I Used the cylindrical mate to align both shafts and a planar mate to align the end of both shafts. Now, when I select the aileron and try to rotate it around the shaft, it doesn't move. It looks that this is because the moving arrows that appear when I select the aileron are not aligned with the coordinates system. If I unfix the wing, then there is rotation, but also lateral displacement of the wing. Can someone help me, please?
if you have anything FIXED then it will not move at all.
it sounds like you need to fix the fuselage and mate everything to that.
There should only be 1 fixed part per assembly. Use group mate to combine multiple parts to the fixed part.
I think I just found the problem. It seems that I have to move the movement control arrows to the center of the cylinder used for the mate. Will check further into it to be 100% sure.
