Why Can't I revolve Sketch 2 ? It should be a bowl with the profile of Sketch 2. All else gone.
  • _anton_anton Member, Onshape Employees Posts: 509 image
    It looks like the revolve is creating something nonmanifold. As a debugging step, I'd move the two top corners of the bowl sketch so that they're not coincident with the block edges, and to revolve-remove negative volumes instead of the bowl volume itself.
    I managed to convince it to at least regenerate like so: https://cad.onshape.com/documents/56a716a27a35b42f36c07d8a/w/ade5e396197a15bb4b8eeeb1/e/73500d7e38d3bb489c461ae6
  • EvanReeseEvanReese Member, Mentor Posts: 2,751 PRO
    Cool bowl design! You're getting what's called "zero thickness geometry". It's what happens when you try to do an operation that creates an infinitely thin section of a solid. This can be frustrating for things like your case where you really don't care about that. You can diagnose in the future by paying attention to the red line and red dot that shows up. That's the area that's causing an issue. To fix it, you can just barely tweak your input sketch so it's not sitting exactly on the edge of that part, like so.
  • eric_pestyeric_pesty Member, pcbaevp Posts: 2,499 PRO
    There must be some "zero thickness" geometry somewhere, I can do 359degrees symmetric intersect but won't accept 360... I guess you can't do a just half and mirror as it's not symmetric...
  • paul_bartlettpaul_bartlett Member Posts: 98 ✭✭
    Got it, Thanks All
