Anyone else struggle with forum text formatting?
I find that I'll draft a post, and the formatting looks right in the preview (code blocks look right etc), but then I post it and it gets all silly looking and some of the HTML code shows up and it looks like a mess. Am I missing something or is it kinda buggy?
Being as I’m often using my iPhone, when I have to enter text into small online text input fields or boxes, well when doing so, these boxes can be a bit small to work with, specially if you’re going to have a number of paragraphs. As a result, you will end up having to scroll a lot and that can be kind of a pain
So often I use my Notes app on my iPhone to lay down my text, as it gives me the maximum amount of screen real estate for text input, and then I copy and paste that into the forum field where you make your post
And when I do that, it often leaves extra spacing between paragraphs. So I have to go and correct all of that
The other problem I have when making posts using my iPhone in this forum, is when I quote somebody (i.e. when I press the little quote button at the bottom of someone’s message), well of course it’s gonna put the entire quote into my post.
Now a lot of times I just want to show one or two sentences of someone’s quote, so I go ahead and remove text within their quote
But when I do that, I get trapped within their quote at times, in fact more often than not, when using my iPhone. That is to say, if I want to enter some text as a response to the quote. It’s going to appear within that quote box, within my post.
So to remedy the situation, I have to pull out my MacBook Pro
more text
Edit: of course it worked this time
First i thought it is because it was an old thread but also in new ones i can't see any pictures.
Does Onshape forum use such a special hoster? I usually never have a problem with blocked URLs.
