Creating a plane perpendicular between two points
I have a drawing exercise I use for teaching with a cuboid. I want the students to be able to create what look like pipes which start on one face and flow to another.
This requires drawing a sketch on the two faces and then creating a spline between the center of these two points to use as the path for the pipe/tube.
From what I understand I need to create a plane that passes through these to points in order to create the spline.
I can't find ho to do this. How do I create this plane?
Cheers
Cheers
https://cad.onshape.com/documents/2636e9556444046757e931d0/w/16afce0507b11d39d90d789e/e/7bf4c0678d505b92ffb9c502
You locate the start and end points, then create a spline with starting/ending directions based on the look that you want. If you need more control, @Evan_Reese's fit spline might be useful: https://cad.onshape.com/documents/cd51f29c6937305f86a9df95/w/86ce0e7568faacfe3963e35b/e/44de484ba0acba52f99fcfc5
Thanks for the responses here
EDIT: Apologies, I just notes the link above for @Evan_Reese tutorial, thank you
