Set text in "text sketch" as part number from part properties?
Triton_Engineering
Member Posts: 14 ✭✭
Hi there,
Does anyone know if it is possible/know of a way to get the text in a "text sketch" to match the part's part number from the properties dialog (update automatically if part number is changed for example)?
We use onshape's auto generate part # feature. We like to emboss these part #'s on the parts we 3D print and currently we simply manually enter the part # in the "text sketch" feature, then extude, etc.
Looking for a way cleaner/more efficient way to match this text sketch to the part#. From what I've seen it doesnt look like it is possible to "pull" the part# from properties in a part studio but I could be wrong.
Thanks!
Thanks!
MichaelPascoe
Member Posts: 2,744 PRO
Currently, this is not possible, see this improvement request: getProperty
Someone correct me if this is wrong.
Work around:
If you generate the part number yourself with a custom feature or API, it is possible to give the part a new ID and Name automatically. However, this would not take advantage of Onshape built in part numbering.
CADSharp - We make custom features and integrated Onshape apps! Learn How to FeatureScript Here 🔴0
Work around:
Partner de PTC - Onshape Averigua a quién conocemos en común
