Sheetmetal corner
Axel_Kollmenter
Member, pcbaevp Posts: 437 PRO
Hello everyone,
how can I achieve that face1 is planar with face2 without the cornerfreecut shown in the second picture?
I´ve tried a couple of methods yet but none of them work like it should work...
https://cad.onshape.com/documents/318b529297096e4fbad95dc6/w/7e8fbf9f7584686fcc22a9c4/e/b8932c65fc6acb918200b8c8?renderMode=0&uiState=6253df0b68340627a5eb8279
It should look like the following picture but without the hole in the corner.
So the corner has to be like the corner in the first picture but de faces has to be planar.
Best regards,
Axel Kollmenter
Axel Kollmenter
@axel_kollmenter_, you're on the right track by finishing the sheet metal. But you will likely need to apply curves and surface modeling tools to fill the gap. There are several good lessons on both topics in the Onshape learning center.I took a stab at filling your corner gap by first trimming the sheet metal back to purposely enlarge it. Then I added bridging curves, filled surfaces, and enclosed. The resulting surfaces are not very elegant and would certainly benefit from guide curves and further refinement. But it's a start.
Thanks for your reply @matthew_stacy but this is not the exact way how I wanted it. I attached a picture how the corner should look like
(But in this case both lashes are bended with 90°. In my case (linked document in the question) one lash is bended by 90° and the other one with 45°)
In this case I cant use a Butt Joint Feature...
So in this picture we have a closed corner and face1 and face2 are planar.
I want the result of this picture in my linked document.Best regards,
Axel Kollmenter1
