Feature script for Tube
wayne_sauder
Member, csevp Posts: 649 PRO
in General
Does anyone have a tool for tube routing? What I am trying to do is select points with various XYZ coordinates and the feature would make a straight run from point to point. Where the path passes through a point I need to be able to have precise control of a bend radius? This would be for a tube that is made on a standard tube bender. It seems all the workflows to do this are rather convoluted.
https://cad.onshape.com/documents/e9510fd9afb962d7ce9a8022/v/c0fbb184e647118cac3ae0ce/e/13b3e0761b89e89cacdcb732
There's also this one, which has a slightly different workflow, and has some basic tube sweeping.
It sounds like a custom FeatureScript would be helpful, especially if you want to model any of the distortion that happens on a tube bender.
@S1mon
Thanks, fellows, I actually had all these tools already, was just suffering from a mental block on getting what I wanted.
Your suggestions got the creativity going again. I do think that this could be a good candidate for a single feature script to do everything in one step??? Let me know if anyone writes such a tool.
Sound great keep me posted!!!
