Line direction doesn't generate correctly
ilya_iablochnikilya_iablochnik Member Posts: 2 EDU
I've created two 3d vectors
direction (0.02492666145987452, -0.07236808061676614, 0.9970664583949808)</code>(0.025 meter, -0.07258100000000003 meter, 0 meter)
(0.025 meter, -0.07258100000000003 meter, 1 meter)
</pre>then I've created a line with these vectors, but the direction it outputs is<br><pre class="CodeBlock"><code>
why?
    To get the code block to work, you have to create the block first, then paste the code into it.
    Odd, I know, but can't read your code above.
