Circular Pattern a Wrap
ken_schmidtken_schmidt Member Posts: 2 EDU
I am attempting to circular pattern a feature I have wrapped to a cylindrical object.  It worked previously but I came back and edited the part, changed the diameter of the circles involved and now it won't work.  I created a document for my students to use and the directions won't work for them no either.
https://cad.onshape.com/documents/7a65550a1828ca286813901c/w/852b13ba09a7339d341fa2f1/e/30d3bcd1c32015b0bbc8b11e?renderMode=0&uiState=62716ae68bd195153bc4393e
Thanks,
Ken
  • steve_shubinsteve_shubin Member Posts: 1,116 ✭✭✭✭
    @ken_schmidt
    Your document is not set where we can copy it.
    Without being able to copy it, a person can’t get into any of the edit dialog boxes to see what’s going on
  • nicholas_radzykewycznicholas_radzykewycz Member Posts: 30 PRO
    The error UI hint recommends turning on "Apply Per Instance" as a solution. Not sure if this will work as can't test anything due to above sharing permission issue.
