How can I bend round edges intersecting on Onshape? It is called Edge Bend in NX.
melih_türkoğlu
Member Posts: 2 EDU
I want to bend edges intersecting each other due to manufacturing purposes. In nx this function is called Edge Bend but I cannot do this on onshape. I tried fillet, round fillet etc but no. The first is from technical drawing, second is my part on onshape and the third is from NX.
Thanks for your help!
NeilCooke
Moderator, Onshape Employees Posts: 5,992
"Edge Blend" in NX = Fillet in Onshape. The different colours you see indicate they are different parts so they need to be Boolean'd together first.Senior Director, Technical Services, EMEA1
