can't find a way to boolean...
vincent_bcnvincent_bcn Member Posts: 9
edited May 2022 in Using Onshape
Hi,
I need 1 unique part. I can't find a way to boolean the 3 parts. Is there another tool/method or any idea of what I can do? Thanks a lot. I'm stuck...
  • S1monS1mon Member Posts: 3,748 PRO
    The inside parts (Part 2 and 3) share an edge. The Parasolid kernel (the underlying 3D engine which drives Onshape, NX, Solidworks, etc) can't do a Boolean with things that intersect at an edge. You might be able to Boolean add Part 2 to Part 1 in one feature, and then in another Boolean feature, add Part 3 to the result of the first Boolean.
    Part 3 and Part 1 also look like they are intended to share a surface, but in fact have a weird gap/overlap situation.
    Overall, I really wonder why the sketch for the revolved shapes are created with so many line segments. It seems like something which would be better with a spline or some arcs. You're also creating things that could just be revolves with a sweep in one case and a loft in the other. If in fact the shapes are revolved, it's generally better to use a revolve.
  • vincent_bcnvincent_bcn Member Posts: 9
    Hi S1mon, thanks for the post. I'm using Onshape for 3 month now, so this kind of comment are perfect. I will try to symplify everything.
    I can't do that, a weird red line appear and I cannot figure why Onshape is ponting only this one. I made the link public.
    I used the revolve and sweep tool. What do you mean?
