<p>Welcome to the Onshape forum! Ask questions and join in the discussions about everything Onshape.</p></p><strong>First time visiting? Here are some places to start:</strong></p><ol style="list-style:inherit;margin-left:25px;"><li>Looking for a certain topic? Check out the <a href="https://forum.onshape.com/categories">categories filter</a> or use Search (upper right).</li><li>Need support? <a href="https://forum.onshape.com/post/question/community-support">Ask a question</a> to our <a href="https://forum.onshape.com/categories/community-support">Community Support</a> category.</li><li>Please submit support tickets for bugs but you can request improvements in the <a href="https://forum.onshape.com/categories/product-feedback">Product Feedback category</a>.</li><li>Be respectful, on topic and if you see a problem, Flag it.</li></ol><p>If you would like to contact our Community Manager personally, feel free to <a href="https://forum.onshape.com/profile/6/LouGallo">send a private message</a> or <a href="mailto:lgallo@onshape.com">an email</a>.
</p>
</p>
How to do this spring
max_mistarz
Member Posts: 5 ✭
hello everyone. Is there any way to make this spring? It need to be tapered at the both end. I cant find any solution in the web. I can do the spring but i dont know how to tappered it at the ends? and how to stretch it in assembly studio?
@Axel_Kollmenter is right, @Evan_Reese could totally do this. But perhaps not at 6:30 in the morning?
@max_mistarz, here is one approach you could start with. Keep in mind a split part or face feature usually works fine, but in this case it did not; so I used Thicken and Boolean subtract as a work around.
Link to example document- Sketch the main shape.
- Revolve the main shape as a surface.
- Split the main surface with a helical surface.
- Create a profile sketch normal to the end of the new curve along the face of the main shape.
- Sweep the profile along the curve.
▚▞▚▞▚▞▚▞▚1 -
@MichaelPascoe
this is exactly what I would have done.1 -
Thank you very much. That is what i was looking for0
@MichaelPascoe
Haha sorry. I´m from Germany, here it was 10am ^^
Your solution is great! But how did you do the squeeze in the helix? I checked the document you linked to your comment but I dont understand how.
EDIT: ok I think I got it but its a bit too complicated for me right now. I couldn´t have this done alone yet.Best regards,
Axel Kollmenter1
