Anyone know how to fix this error?
andrew_bekheitandrew_bekheit Member Posts: 2 EDU
It says Extrude 8 did not regenerate properly: Failed to Extrude selections, check input.
Heres is the project if you want to know what it could possibly be https://cad.onshape.com/documents/d655ea931de1a2af764e8616/w/0eced8708364b1603c78c68f/e/85c110ff32ce13d0d5d547d2?renderMode=0&uiState=6296db2bbc208d7d79b55232
  • wayne_sauderwayne_sauder Member, csevp Posts: 628 PRO
    edited June 2022 Answer ✓
    @andrew_bekheit
    Here is one problem. The kernel does not allow this type of geometry. In order to find this, I had to get rid of all the extruded faces you had in extrude 8, reducing it to only the sketch Maze. I normally try not to put that many faces in one extrude command.
    @andrew_bekheit
  • andrew_bekheitandrew_bekheit Member Posts: 2 EDU
    Ok Thank You :smile:
