Keychain Text Automation
xphilip
Member Posts: 17 PRO
Looking to automate the creation of these keychains.
The input is a text string, but then it gets tricky.
Each character in its correct location needs to be extruded to different height - no idea how to do this, this is the sticking point.
After that it's fairly easy (i think) - offset the vertical faces to ensure that I can then boolean all the bodies together and export as 3MF/STL
Some smart person here surely knows how to do this
https://cad.onshape.com/documents/94898019595c6cb408523bed/w/8957b82c6872db5bf9d83dbd/e/2d597c127db87b4415e4e860?renderMode=0&uiState=62bdaf32affec83631318d53
@_anton - THANK YOU!!!!!! (MichaelPascoe - I know you were just pipped at the post -sorry, but also thank you )
I will leave this post here as of course all can learn from Antons solution.
Philip
(It was bothering me.)
