Total Newbie.
chris_dragottachris_dragotta Member Posts: 2
I'm a saxophone mouthpiece craftsman and I want to learn CAD.  I am signed up for a 14 day trial and I have an .stl file of a sax mouthpiece that appears when I load it, and I want to discover how to use the software.
It seems that nothing I do to make a change to this file works.  I change dimentions and click the green check mark.  Nothing.   Is the .stl file not editable?   Is my trial not allowing me to make changes?  I see no way to export the file to other formats.  All I want to do is change the shape and export as a .dwg  file or some other generally acceptable CAD format.   Can some one offer me some advise?
  • Axel_KollmenterAxel_Kollmenter Member, pcbaevp Posts: 436 PRO
    Hi Chris,
    check out the Learningcenter there are tons of great and short tutorials to everything you need.
    Best regards,
    Axel Kollmenter
  • S1monS1mon Member Posts: 3,860 PRO
    STL files are not really designed to be edited (they were created for 3D printers). Onshape added a Mesh type which allows some ability to do solid features on top of a Mesh (from an imported STL), but to do truly parametric CAD, you’ll need to model the features yourself.
  • dirk_van_der_vaartdirk_van_der_vaart Member Posts: 561 ✭✭✭
    Create an account at Grabcad there you can find beautiful design,s of what your looking for, with editable step files.
