Exporting an Assembly to SLDASM
kenn_sebesta167kenn_sebesta167 Member Posts: 113 ✭✭
Can OnShape do this? I see I can export individual parts to SLDPRT, but when it comes to exporting the assembly SLDASM is not a default option.
  • NeilCookeNeilCooke Moderator, Onshape Employees Posts: 5,988 image
    No, but you can export as Parasolid and SolidWorks will read the assembly structure. Make sure you choose an older version of Parasolid as SolidWorks is usually several versions behind.
