a suggestion about the color of dimension lines
shanshanshanshan Member Posts: 147 ✭✭✭
when a sketch is constrainted totally, the color of  all the entities is black . but sometimes when giving many dimensions to a complex sketch,due to the same color for the constraited entities and dimension lines, it is not easy to distinguish if a line is constrainted or not from visual sense if many dimension lines passby this line ,so I  want to suggest that if the color of dimension lines can  be changed ?
    +1 Very good point @shanshan, I would like to add that if there is a way that the extension lines didn't exist until the dimension is actually extended from the part would be ideal.
    Good points
    +1
    Is there IR up for voting?
    //rami
    edited October 2015
    +1.
    Good point @shanshan
