Mesure distances in section view
brunono553brunono553 Member Posts: 13 ✭✭
Hi,
I'd need to be able to mesure distances while using section view; exactly like if I cutted the parts I need to mesure by the section view plane. Something like this: (I actually cutted the part for doing measurements)
  • Options
    _anton_anton Member, Onshape Employees Posts: 279
    You'll need to actually cut the parts to measure them.
  • Options
    MichaelPascoeMichaelPascoe Member Posts: 1,724 PRO
    I would also like this functionality. Until this functionality is implemented, here is a custom feature that may speed your process up: Section View
    CADSharp  -  We make custom features and integrated Onshape apps!   cadsharp.com/featurescripts 💎
  • Options
    edited July 2022
    And how can I do to achieve that kind of measurements when I'm exploring versions ? As versions are read only, I can't do this split
    So I've to branch, then split. Quite an heavy process for a simple measurement
  • Options
    Thanks ! This is brillant and certainly will speed up my process !
  • Options
    edited July 2022
    Hm, you could branch the version, then split the model. Onshape Learning Center - Branching and Merging
    Just remember to go back to main for your real work! I have found it tricky to know which version I'm in and have spent hours making changes to the wrong branch before... Perhaps there is a way to be notified or make it clear if the user is not within "Main".
