Instructor Kit: In-context part design 2 (Step 10)
josh_baker673josh_baker673 Member Posts: 2 EDU
I am trying to make a cut to remove the inside face.
The tutorial says I need to choose a specific end type.
No matter which I use I end up with a cut all the way through, or not at all.
https://drive.google.com/open?id=0B1wxccE28_iIZzRtS19ZUmdVaFk
    edited October 2015
    This topic may help. https://forum.onshape.com/discussion/1133/extrude-remove-offset-from-surface-to-retain-wall-thickness
    Contrary to what the tutorial mentioned by @josh_baker673seems to me to imply, there is currently no "offset from surface" end condition in Onshape
    Another option to create this cavity would be "Shell", and this would automatically maintain a constant thickness in the end wall. However it would not make use of the existing offset sketch geometry.
  • josh_baker673josh_baker673 Member Posts: 2 EDU
    Thanks for the first idea. The shell command was my first instinct but it didn't work.
    The instructor kit I think needs some updating. I am teaching a group of high school students and I am making sure I hit the problems before they do.
  • noanoa Onshape Employees, Developers Posts: 141 image
    Hi @josh_baker673,
    You are right, there is no way to do that currently – those steps are based on old functionality that has since been updated. We will post a fix to this in an updated version of the kit soon. Thanks for catching it!
    -Noa
    Noa Flaherty / Customer Success / Onshape Inc.
  • james_famiglettijames_famigletti Member Posts: 1
    Any update for this problem yet?
    Thanks for checking in @james_famigletti. The Instructor Kit has been fixed for a while and thanks to your reminder, the Intro to CAD Series was just fixed. You can find the most up to date version at either of those links.
