Quick select the right origin plane
Axel_KollmenterAxel_Kollmenter Member, pcbaevp Posts: 436 PRO
Hello everyone,
is there an easy way to quick sort trought the different planes with a mateconnector at the origin? Or do I have to rotate and try until I can select the right face? This time I wanted to select the face which ist rectengular to the y-axis.
Best regards,
Axel Kollmenter
  • Alex_KempenAlex_Kempen Member Posts: 258 EDU
    If you highlight the origin with your mouse (such that the grey mate connector axes appear), then press and hold shift, your current selection will lock to the origin, allowing you to select a mate connector axis much more easily. Pressing and holding shift can also be used to lock selections to faces and other types of geometry, which makes it a lot easier to select the implicit mate connector you want.
